Identify the lift
geswek
I found a truck in our parking garage today that is exactly what I want to do to my Z71. Without being creepy (by leaving a note), I elected to take photos and see if anyone could identify.
Tires are 35x12.50x20 -- what size wheel would require that and what kind of offset does that look like? 20x9 -18 offset?
What kind of suspension lift is needed to look and fit that?
Thanks for all the help :)
I would think that is at lest a 6" lift. It's to dark to make out if it has a body lift.
I was thinking 6" lift as well -- was looking at RC's 6" lift but they say it only supports 33" tire.
I talked to RC and they said I would need 7" lift to clear 35's
My other option is to leave note and have the doctor text me--which may not be that bad considering I am the IT Network Manager here.
He has a 6" or smaller -- I just noticed his lower fascia is trimmed. Someone cut it out at an angle.
Solved.
I went back out and saw it's a Pro Comp. I called the dealership that was on the truck and they send it to an outside source to build. I called them and it's a 6" Procomp Stage 1 with 20x9 wheels.
Solved.
Good looking truck. My buddy started a thread yesterday saying he was told he could run 35"s on just a 2.5" level and i told him i thought he would need a 6" lift based on other posts ive read. His are oem 22"s so his offset is alot milder tho. Anyone have any ideas if it would work? Im running a similar setup to his, and would also like to know for myself... sorry to hijack this thread, but he isnt getting much feedback on his thread and figured id ask here
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 446 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
