Need Help with Aftermarket Wheels
spokenword
2014 Silverado
26" Wheels
305/30/26
Brand New Dub Baller Wheels
My truck has a violent shake right at 65+mph
-Road Forced Balanced
-High Speed Balanced
-I've removed all rotor retaining clips
-Wheels are hub-centric can't use hub ring
-Even tried a different set of lug nuts
Looking to see if anyone may know what the problem could be.
2014 Silverado
26" Wheels
305/30/26
have you lowered it?
Not enough rubber [emoji14]
Sent from Tapatalk App - Samsung S6
No, I had the front leveled and aligned same day the wheels were put on.
my truck was shaking a bit at the same speed with my 26's.
I rotated the wheels and it stopped.
I had them balanced again though. try getting them balanced again at a reputable shop
lol these trucks shake on stock anyway.
This is your issue it's on the back of your truck 1a1d18bacc48d3a174f0703ba7f09439.jpg
Little clip that sits on the stud take rear wheel off you'll see it.
Sent from my SM-G900W8 using Tapatalk
#2
#2
He already said he'd removed those.
Please post pics, wanna see 26" hoops.
Yes. They look damn good on my truck.
Then it's probably a bad balance only other reason
I ordered them from CarID which made me assume they were going to be balanced perfectly. It's all just frustrating as hell.
Can't assume id go to a local trust worthy shop explain the situation and ask them to check it out for you iv had this issue in many cars and they might not all be out could just be one wheel is off but that's enough to cause it to do that or like I posted earlier you have one of those clips still on the rear stud
30 series? holy shite that is quite a shoehorn to get them on lol. Are they run flat? LOL JK. That's crazy low pro. please post a pic
Do you still have your old tires and rims?
Mark your new rims/ tires 1-4 with chalk, install old wheels in rear. Rotate the fronts to isolate which one's shake. That assumes at least 2 of your 4 are good. If the vibration is from less than 3 wheels you can at least identify those with an issue and without, if it is balance or run-out.
If you have a 2wd you can do 1 at a time on the front...
You could also try all of your old wheels in case there is something about your leveling job? Why assume...
I agree, very little rubber. I test drove trucks with 18's and 20's, the trucks with 20's rode worse. But it is impossible to say if yours are normal for what they are. Good luck
Thanks I'll give that a try when I find time and let everyone know how it turns out.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 426 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
