TYRICH88's 2015 Z71 BUILD
tyrich88
I posted this in my old build thread but am just now getting around to starting this one.
I traded in my 2014 LT 4X4 CC for a new 2015 LT Z71 CC a few weeks ago.
Here she is the day I got her:
FCBC4F90-3306-4009-B659-F53C69A213AB_2.j
  • Replies 100
Nice! Did you pick it up with the level and REAL tires?!?
My buddy that is the salesman had it leveled and aligned and took my brand new tires and moved them over from the old truck.
I also got to keep my bed mat, grill guard and running boards.
Picked it up and left the next day for the mountains to go snowboarding with my brother:
These new BFG KO2's are great in the snow!
Got 7" of snow the night we got there, so awesome powder all weekend and i got to test the new tires out a bit too.
Here it is post trip after all the salt and everything on the roads:
Here are a few more pics from the trip. The snow was awesome for being so early in the season.
Got the bowties taken to black last week
Also did the bowties on my wife's equinox:
Got the grill guard and running boards put on this past weekend too.
This is the only pic I have currently.
Not a whole lot. Got the Z71 package, trailer brakes and sliding back window.
But it's new without all the miles the other truck had.
Also, the other truck had hail damage and scratches on the tail gate that were there when I bought it, so I traded it in on a brand new one.
  • 4 weeks later...
Going to the exhaust shop this afternoon to talk about which set up i'm going to go with with the guys up there.
Also ordered some new bulbs for my low beams. I'll post pics as soon as these updates get installed.
Got the truck picked up yesterday afternoon from the muffler shop. I got a 14" Magnaflow muffler with 3" pipe from the Y all the way back and cut out the third cat.
They did a turn down right at the bumper for the tail pipe.. I'm a little unsure about it because I carry some high end mountain bikes around with me and on a hitch rack they may be exposed to the heat of the exhaust, which can melt the carbon fiber in the wheels... not something I want to happen.
Before:
C9CE3455-6E1E-43FA-AB5E-09FDAED604CE_4.j
After:
Here are a few sound clips I got last night and this morning as well...
Here's one I got this morning leaving the gym
Before:
After:
I'm looking at getting my exhaust system done as well. In respect to a shop, what type should I go to? One that specializes in mufflers or a performance type place. Thanks in advance. Truck sounds awesome in 2nd vid..
Sent from my SG Note 4 on Tapatalk
I went to a muffler shop here in town that I've dealt with before. They custom bend their pipes for exhausts.
I would look for a place that does their own stuff, it's typically cheaper and you can customize what you want.
Mine would typically come with 2.5" pipe and not cut out the third catalytic converter, but I wanted that cut out and at least 3" pipe all the way out. I found out they could do it and went with them.
Dont go with crinkle bent pipe, it hinders the flow.
It's hard to specify whether you should go performance shop or muffler shop. I would just ask around and do your homework before you go with someone. If you have questions PM me and i'm happy to help!
Thanks brother, appreciate it..
    DaleB
    DaleB
  • Who's Online   5 Members, 1 Anonymous, 1,522 Guests (See full list)
    • Hi all - my current truck is a 2022.5 1500 High Country 3.0. I bought the truck used last year. After doing some digging, I noticed that my truck's software is stuck on the original build from 2022. I have no available software updates. I talked to my dealer about this and they recommended not trying to force an update since the 36,000 mile warranty is expired. This is a big bummer since there have been many major releases since that have fixed small issues and improved speed/usability.   For reference, the current software build number is: full_gminfo37_gb-user 10 W158E-W164.4.2-QIH22B-563.3 158 release-keys Has anyone had a similar experience? Should I just forget about it and move on, or try a different dealer?
    • Sure. Buy it for me 🤣
    • Using zip ties but 2-3 they snap due to sharp edges. Just using a shoestring. Last longer. 🤣
    • I ordered the Snap On...waiting for it to come in later this week or early next week.   New front cover, new crank seal and new balancer are on. Water pump, pulley, fan, hoses, and plastics reinstalled. I can move forward knowing all my timing marks are dead on and the front engine is hopefully sealed better than it was. Take 2 with the water pump...trying high temp thread sealer on the lower bolts.   Rebuilt injector and new-new regulator is in, it looks like new. Top intake reassembled and all the bits are reconnected and snugged down.   Thinking about knock sensors again, I located both of mine and, there's your problem, Francis... The driver's side one is broke, plastic is bashed in, part of the wire is bare, and it appears to have been damaged like that for a long time. I saw the wire but didn't think anything of it. The knock sensor might not be my pulled timing issue, but it sure looks suspect. It must still be conducting, otherwise I'd expect a CEL. But perhaps with its sacred crystal inside exposed, jilted and dirty, maybe it's sending mixed signals. So I'm waiting for one of those and a new pigtail to come in. Pass side sensor looks good, except for the spark plug wire resting on it (!). The plug wires are healthy so it shouldn't be causing an issue, but I separated them and added zip ties to nearby looms to keep everything well apart.   So, I'm down to installing a knock sensor AND, oh, replacing the exhaust and cat. I actually think that's going to be fairly easy, it's all bolt-together, all new stuff from Walker is laid out on the shop floor ready to go. Hopefully have this thing on the road again for the weekend.   My luck? It will still be leaking oil, coolant, pulled timing, intermittent CEL for running rich, or it probably won't run at all -- because that's how this project has gone.   I've never worked on a vehicle so ...hurt? ...cursed? in my life. Everything has been effed with SO HARD, but I think...knock on wood...I've managed to undo all the backyard stuff and we're almost reset back to "just" an 80k mile, 30 year old Blazer.
    • Yes. You need to check out that thing, and the hub further.
