Whipple or Magnusson supercharger for SierraDenali 6.2?
toro1966
That's BS most GM techs don't even know what a melted piston looks like or a lifted ring land for that matter. I would take the short block to an engine builder for expert analysis not some ass munch that makes $10 an hour!
RT
  • Replies 73
He's costing me money directly and indirectly. I don't want to get into the direct part, but poseurs like this guy are partly the reason GM is denying warranties and costs are going up and warranty coverage getting shorter.
Taking the blower off and trying to pass it off as stock was kind of shady in my book, but hey, no harm in trying. Getting lawyers involved because they won't pay for your play is BS that costs the rest of us money.
I see what you mean and although i am 100% for the consumer..... Here its a loss... You know what you are getting into when you put a blower on your truck..... If it blows up... Well its hard to have the dealer fix it.
I mean they will fix it but u better bust out that checkbook!!! Lol
Sent from my Note 4 on Tapashit
If the Injector caused the problem it's on GM not the Huffer. The auto makers use this as a way of getting around their cheap ass parts failing. IMO GM will have to prove that the aftermarket part caused the issue which they can't....the supercharger is their scapegoat at this point.
RT
A bad injector is *not* going to melt a piston on a stock motor.
RT
Those ass munches make a whole lot more than $10 an hour.
Also, for that scenario, it's almost certain GM had an engineer involved.
I'm kind of surprised you can run stock injectors, fuel pump, etc.
Probably went to 100% duty cycle and just failed. Or am I just behind the times? I guess DI is a whole new ballgame.
I'll add that the builds I'm seeing with FI, they all look conservative. DI is a game changer, but I think it's more to do with the higher compression levels DI allows than DI in and of itself.
Debating a blower myself on my 5.3L. If I do, I'll definitely be upgrading to the LT4 fuel system because I'll be running E85.
I'm all set for E85 already from the factory :D
Since the lobe on the cam drives the fuel pump most are getting custom grinds to have it keep up. ...what I have yet to see is where the wall is to where the stock pump cant keep up no matter how big of a cam you have?
It may not melt a piston but in a lean condition or failure of the injector *will* score a piston
RT
Foo.c Google magnusson-moss act of 1975. The lawyer I hired has dealt with this before. Since my truck has been at the gmc dealership, there's been 2 other STOCK 2015 6.2's with injector problems. Sorry for the bad news, but I will be getting a new motor. It'll just take a while. 07 softail thanks for the input, I agree with you 100%.
You got them to cover your truck after you blew it up with a blower on it?
I applaud you sir. Wow..
Of they cover your truck i will have to take mine to that dealership because my girl got denied warranty work for squeeky leafs because she has a level and large tires lol
Whipple and don't look back........But then again that's just my non bias opinion ;)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
