Bigger tires
Jeff3955
Looking to put a leveling kit on my 2016 3500HD Denali. Has anyone done this? Just curious of what size tires I can go to with the leveling kit. Don't want to go to big because I don't want to mess with the ride quality. Has anyone done this? If so did it mess with the ride quality a lot?
guess you are leveling from the front. I did it from the back with a set of lowering 2" McGaughy's shackles. I didn't like my 2500 looking like a cat in heat with all that rake. $67 total cost.
Did this affect your ride at all? Still want it to ride nice. I will also be using this truck for towing a 5th wheel trailer. Will lowering the rear affect the amount it can tow? I guess I could add air bags too.
Not a bit. Ride identical. just a LOT easier for these old bones to get in and out of the truck bed when I need to. I primarily haul instead of tow, and I have put on quite a bit in the bed and not had any issues. I have not considered air bags, as I have not found a need to do so. Granted, I have not put in a full 2300 lb that would bring my 2500 up to gross, but I have had several 55 oil drums, concrete, bentonite, etc in the back and not seen the lowering as a problem. It just doesn't squat that much. A far cry from something like a 1500, where you put more than 300 lb in the back and it squats a little. But air bags are a nice addition to any tow vehicle. The drastically improve the ride and handling. That is why most commercial heavy trucks are on air. My semi truck and trailer is totally on air. Not a spring in sight.
Cowpie's suggestion is an excellent one if you're looking to level, and stay stock all way around. If you're looking to go to a larger tire, then you'll need to level from the front. Search it on this site, and you'll find a ton of good information. After doing that myself, I saved the price of a level kit, and just turned up the torsion bars. I got close to 2", and I fit 295/70-18 Nitto mud terrains with zero issue. Another search will show lots of guys on here have done the same thing with great results. In my opinion, the ride is better after turning up the bars, but I believe it to be because you're no longer riding on or close to the lower bump stop.
If I could afford adjustable rear air bags right now, I would definitely go that route. Hands down, the best option available for anyone that uses their truck for actual work.
Thanks for the info guys. After doing a little research I'm just going to level the front 2" as I also want to run 295/70/18. I can't imagine noticing a huge difference in the ride. Later on I may add the cognito or CST upper arms and then put bags on the rear for towing my 5th wheel.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
