Center Console Removable Cup Holder Assembly
I have the center console (power bucket seats) with two open holes (trays) forward of the console lift cover. The truck came with a cup holder (2 cups) assembly that can be placed in two different locations. Anyone know if there are other options to replace the cup holder assembly or even purchase a second one for the existing style? I cannot locate the cup holder anywhere in the parts or accessory catalogs nor can my dealer.
Just note that you can't put both cup holders in at once to have 4 cup holding spots. They don't fit together.
I tried this before I bought my truck.
Well, there is another thread on here where many of us have both. I have them in my console and they fit just fine. On the front one, I trimmed the guide on each side and it doesn't snap into the holes, but it fits and stays there. I had two large coffees and two large styrofoam Cokes in the console today. No problem.
There are 3 different ones
Burnish: 23177378
Black Carbon: 20988607
Axiom: 23177377
Thanks. I am not sure why it is so difficult to find parts or get a straight answer from the dealer. In the dealer's defense, GM has made it difficult to do anything on these trucks which is not a factory option. I loved my Toyota Tundra for that reason. Everything was PPO, pre-wired, pre-drilled and plug n play. I just had to buy the parts and install.
Can you send pictures of what you did to get them both to fit please.
I would love to have a second cup holder in my truck as the rest is wasted space as far as I am concerned.
I would like to see what I would need to do to get them both to fit.
Thanks for the response as well on this Chuck.
I'll try to take some pics, but essentially I just used a Dremel to remove the track guides on the second one and it snapped right in. No, it does not snap into the slot nor do the ball bearings snap into the dimples, but it doesn't go anywhere. I also learned a lot about the various colors...very confusing...here's the link to the other thread with pictures...
http://www.gm-trucks.com/forums/topic/177119-center-console-area-by-cupholders/?hl=cup+holder&do=findComment&comment=1680797
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
