Diablosport tire adjustment
Hello everyone, I Just installed my lift on my Silverado and I am running 35" tires. I measured them and they came out to be 35". When I went to adjust tbr speedometer though, it is still off 4 miles at 60mph. I went down to 34" and it seems to be off by 6 if I remember correctly. Does anyone have any advice on setting these? Thanks!
