New Guy
hjcarnell
Hey everyone,
I'm new to the forum and to the GM family. I just bought my 2015 Chevy Silverado 1500 CC 4x4 LT. Previously I had a 2008 Dodge Ram 2500 lifted on 37s and all the delete goodies but it was time to get something a little more practical for my needs. I've had the truck for a little over a month and I love it.
So far I have leveled it, added tint and a tool box to the bed. I don't plan to do much else but black out the bowties to match the gorgeous black paint. I'm in the Air Force and have been for almost 12 years and stationed in Charleston S.C. but born and raised in Pennsylvania. I don't know how else to make this intro any more awkward but I wanted to do an intro and hopefully this forum isn't like my experience on Cummins Forum with rude moderators.
Welcome to the group. Glad to hear you're lovin' your Chevy! I still smile when I drive mine -- been a little over a month.
Thanks for the welcome. Here is the most recent pic I have. I will take more since I have added a black tool box. I still love this truck and thought I would miss my Cummins but so far I don't at all. P.S. These trucks should come leveled.
  • 3 weeks later...
Can anyone tell me what wheels I have? I know they are 18's but In the wheel and tire thread I can't find them anywhere.
