Need some help. "unkown driver" Nothing in the interior works,
Brando5641
2004 Suburban Z71
Truck was dropped off for displaying unkown driver and wouldn't start. Truck has 2 keys and they both do this. Had the vehicle for 3 days and started the truck 30+ times and couldn't recreate the symptoms. Gave the truck back and got a call the next day it had done it again but now the truck will run but nothing inside the truck works. Hooked my scanner up to it and it wouldn't connect. Had 7v on pin 2, pins 4 and 5 have good ground, and 16 has 12v+ at the DLC. Started doing some searching and found a TSB for this issue and it stated to check the wiring under the drivers seat and the ECM harness next to the battery box. Both appear to be fine.
Not being able to communicate with the vehicle I'm assuming its a serial data issue.
I found the SP205 splice connector and jumped pins B and M and was still not able to connect to the truck. The writeup i found wanted you to take jumper wires and one at a time bring each module online and then when you lost connection the last one to bring online was the issue.
I'm at a loss of how to proceed. Gut tells me its the BCM but I need some assistance on how to diagnose this issue better to avoid throwing money at it.
Your post sounds like you are a repair facility. One thing I have always done when I was still on the bench was to admit when something stumped me, and tell the customer that they are best off going back to the dealer for something like this. I hate working for free almost as much as I hated charging customers for my learning something. Once you charge them for fixing it, and two days later the same issue returns, I could not ask them to pay me again. Did not take many instances of that happening before I started just being straight with them. If I was not confident in my recommendation, I would simply tell them it was beyond my skill set. About the only thing I hated more than being wrong was getting caught at being wrong. Customers will trust the mechanic that is straight with them first.
I'm not a shop but working on it for a friend. I agree I am past my capability's with the equipment I have. I am going to take your advise and recommend he takes it to someone more well equipped. I hate to do it but I guess you cant win them all.
Here is a prime example of why I HATE modern vehicles.
I'll take the poor fuel economy and increased maintenance of points and a carburetor any day of the week over problems like this. :nonod:
We had similar issues back in those days as well, bad connections in the bulkhead disconnect for example. Or bad grounds on one of those 14 wire daisy wheel connectors that was the very first thing bolted down, then the dash was built up on top of it (1973 Imperial for example). Idiots used a sheet metal screw to hold it down, no form of any locking washer. They changed to a 1/4 inch stud the following year, still hidden though.
At least in those cars, if I was faced with that at my house, I'd just rewire the circuit myself, bypassing the connector altogether. Do that on a modern vehicle, and it won't even run. :nonod:
    • More is cylinder deactivation. Kia-Hyundai Ive had 4. The warranty is the same 10 years 100K miles. My grandson drives the first one 05 Elantra GT. My wife drives the second one 2011 Genesis. The Genesis still performs as new and looks great. The Elantra looks rough. He’s not kind to it. The third was a Genesis coup. The fourth was a Santa Fe. Those were my daily drivers. I don’t keep them long. Kia is the same as Hyundai with the same warranty. I looked at the K-4 today. Too small, otherwise pretty good buy. Most of Hyundai and Kia’s have a performance upgrade.
    • Thanks for the point of reference
    • Great question. Answer....depends. One the volume of the crankcase, the driver that will actually be using the vehicle and the amount it uses plus the distance expected for that next trip. Couple of for instances:   Wife is going to drive Dizzy to Moline and back plus a bit around town so say 500 miles on the day. I know from years with that SUV that around town and local rural it uses about a quart in 1250 miles. But on the Interstate and her at the wheel without her anchor nagging her she'll push it and it will drop a quart in about 800 miles. Hence, around town I wait to somewhere between a quarter down to a quart down. On her trip I'd top it if it was down a few ounces and hope for the best.    Have I overfilled one? You mean by adding before it needs a full quart I assume. No, not once after finding the true fill mark.  I know the dipsticks of everything I drive and add what it needs. I learn this by doing the first oil change a quart low. Run the motor for a few minutes. Let it sit over night. Check and mark. Then add half a cup at a time making note of the place on the stick. I add through the dipstick tube with a barbeque basting bottle. Give it a few minutes to drain down and check again.    A vehicle like Dizzy that uses this much oil will take a few quarts between 3K changes. I keep one in the vehicle with the bottle and a bag. (Mindful of it's fullness) Not a big deal and never makes a mess of it. There is no such thing as "multiple quarts' in my shop for any specific oil. There will be a maximum however of the number of different oils used over the fleet.     Dizzy holds a nominal 5 quarts. So the first fill was indeed over as it actually took 4.75. My vehicles are fit with Valvomax valves so I can meter an ounce on the drain if need be. Found her mark first crack at it. Never to be repeated.    Pepper uses none between changes so I don't keep a quart in that one. Straight up 6 quarts put her dead on the full line. Check it ever fuel stop. They will surprise you when they start using.    Raven holds 3 liters or 5.44 ounces over three quarts. I add 3 quarts and 6 ounces. That gives me 5 oil changes on my orphan quart.    Lawnmower holds about 3/5 of a quart. I don't over fill it to prevent an orphan. So yea, depends.
    • 185k on original 6.2L engine and 10 speed. 6" lift with 35" tires. Changed oil (Mobil 1 synthetic) when truck told me to. Original tranny with original fluid and no service or flush done. All highway miles. A/C compressor replaced at 155k. Oil cooler line replaced at 180k. Still daily driver. Love this truck.   This is my 3rd 6.2L vehicle (2008 Yukon Denali / 2018 Cadillac Escalade) with over 150k miles and no issues. Denali had broken motor mount at 100k.
