Is the EPA After Your Hot Rod?
John Goreham
2/9/2016
SEMA, the Specialty Equipment Market Association, has sounded the alarm that the EPA is intending to restrict the modification of vehicle emissions systems for passenger cars converted to racecars. This could have grave implications for drag racing and other motorsports that use sports cars with modified engines. The EPA already feels that it has the right to restrict the conversion of on-road cars to race cars based on the Clean Air Act. Today, SEMA issued a press release warning that the EPA has recently added a comment to a proposal that clarifies that the group has that control.
SEMA President and CEO Chris Kersting said in a statement, "This proposed regulation represents overreaching by the agency, runs contrary to the law and defies decades of racing activity where EPA has acknowledged and allowed conversion of vehicles. Congress did not intend the original Clean Air Act to extend to vehicles modified for racing and has re-enforced that intent on more than one occasion." SEMA intends to challenge the EPA on the point.
hate to say this, but I believe this all leads back to the events of DieselGate, the EPA is Pissed off, and they intend for someone to pay for VW's Illegal Activities, and unfortunately, the Weekend Racers are going to pay the price. (and more than likely, the Manufacturers will pass the price of this DRACONIAN Regulation to the Public through the service department; meaning charging HALF A F*YAY*KING GRAND for a SINGLE SOLITARY SENSOR Will become commonplace!)
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
    • I had an alternator fail that was shorted internally in such a direct fashion in addition to the larger gauge cables that it appeared like a VERY dead battery. Granted I think the car did power up, it definitely wouldn't start.   Rodent damage to wiring?
    • ... I don't think he could.
    • Using experience to justify bad advice is lazy and typical of someone incapable of articulating why their advice is prudent.    This immediately sets off the BS alert and the advice that followed certainly qualified.   Asking an idiot for help getting out of dumb situations because he is an expert... at getting himself into dumb situations.   Unless I've been living in an alternate universe - the first thing everyone does when getting into a sticky situation is shift to a higher gear 🤨.   Of course not, the torque multiplication, mechanical advantage and finer control typically afforded by the lower gear is far better suited for this scenario.   There ARE scenarios where a higher gear MIGHT be appropriate determined more by the drivers ability to control EXCESSIVE wheel spin versus applying torque to the ground.
    • I'm not sure I agree with "extreme" low speed, high torque sentiment here with regards to the prescribed use of low range. How about...whenever it's needed?   A 2.72:1 transfer case and whatever differential gears these Silverados have (3.42's, maybe?) aren't producing "extremely" low crawl speeds. Or insanely high torque multiplication. Even with the 1st gear in these newer transmissions. But it does provide mechanical advantage and potentially better control at slower speeds. And with extra weight or towing, I think it adds mechanical sympathy for the truck as well.   Plus, traction control and the other assists generally turn off when you shift into low range. Those aren't needed here, they'll work against you if you need wheel spin. In high range you'll need to figure out how to turn off the various modes those assists provide. Depending on the vehicle, those things don't all automatically turn off or turn completely off.   While I agree that a farmer might have some great practical experience, a recommendation to "always" using one gear isn't very informed advice. If the farmer had said WHY and could explain the physics behind his prescriptive "always" I'd definitely listen. The way he's described here makes it sounds like he could either be uninformed or is telling everyone what worked for him, not necessarily that there could be a more advantageous way about things.
