OPT7 LED Question
Hello all. I am thinking about picking up a pair of Opt7 LED headlights. The odd thing is, on Amazon it tells me that the 9006's will fit fine. However, it says the 9005's do not fit. The thing is, I want them for my high beams. What has got me even more confused is people say they are both high and low beams?
Has anyone bought these and used them as high beams? Do you buy the 9006 or the 9005? Maybe I am overthinking this but like I said, it's got me a little confused.
  • 1 month later...
I just got the opt7 9006 lowbeam and 880 fog light kits from amazon and so far with just the lowbeams am pretty happy with them. I haven't looked into the highbeam kit yet but I'm not sure if they'd be needed being the lows throw very good light. What vehicle are you trying to put this kit into? I was able to have this kit work great in an '04 tahoe.
  • 3 weeks later...
I bought a set of these for my wifes G8. I was originally going to use them in the lows (h11), but decided since I liked my HID's already and that the LEDs weren't as bright as HID, I installed them in the highs (h9). I know these are different bulbs, but I'd imaging since 9006 and 9005 are so close, they'll probably fit just like they made my h11 fit h9, and vice versa. Try it and find out I guess.
  • 1 month later...
I have the opt 7 high beams, low beams, and the fog lights. They work great and are bright
