EGT Probe for 1500?
Anyone run an egt probe on their 5.3? I plan on pulling a TT and coming from a tuned diesel this has me concerned a little. Is it not as big a deal or just watch tranny temp and engine temp? Will be pulling around 7800 lbs and this has me wondering.
I don't think anyone has mentioned one on the site. As long as you are under the tow ratings for the truck you will be fine.
Zero EGT concerns with a direct injection gas motor, the ecm will pull power if it gets hot, I wouldn't even worry about coolant temps, my big concern would be trans temps and if you are pulling heavy you can plan on adding a large trans cooler as the stock unit won't cut it.
