FWTexas Posted March 17, 2016 Posted March 17, 2016 I'm about to have a 3" BL put on my truck, and I already have a 2" leveling spacer up front. But I really want to change the stock ride. I've been doing a little research and am thinking about buying 4 Bilstein 5100's but when I try to select a size for the front at CARiD.com it says for "3" A-Arm lifted vehicles." I don't know if they will fit? Since it's a 2wd I don't plan on doing a suspension lift so should I just go with the 4600's? And anybody know some good replacement coil springs?
Chris Posted March 18, 2016 Posted March 18, 2016 I'm about to have a 3" BL put on my truck, and I already have a 2" leveling spacer up front. But I really want to change the stock ride. I've been doing a little research and am thinking about buying 4 Bilstein 5100's but when I try to select a size for the front at CARiD.com it says for "3" A-Arm lifted vehicles." I don't know if they will fit? Since it's a 2wd I don't plan on doing a suspension lift so should I just go with the 4600's? And anybody know some good replacement coil springs?Coils i am guessing? If so here is what i used. The front is a touch too long, but they work and are working well for another member on here. I had a 2" level and HD rear springs
