Installed LED Fogs Tonight
And useful? They project out properly?
yes. No. Since I done the fogs with high beam mod I just use them that way.The headlights are so poor on these trucks. They should not be used in oncoming traffic. They also reflect off of snow and fog. They are great in the way I use them which is on dark country roads.
  • Replies 38
What is your HID headlight kit, the Morimoto one or something else?
My HID headlights are another brand I found while searching the internet. I cannot remember the brand or where i picked them up from.
[emoji15] what's the details on those? Never seen them.
Do u have a link for them . Debating on buying some bps gen7 led bulbs or getting something like this .
Or any pics on ?
