Single In/Out Borla for 2014 Silverado High Country 4WD with 5.3L?
TedH
I really liked my single in/out Borla cat-back system on my 2003 Silverado LS with 4.8L. Bought my 2014 High Country and promptly started searching for a better stainless exhaust.
Borla is both MORE expensive (than I recall) and does not seem to offer a single in/out system. I see single in/split dual and single in/double right outlet. Are my only options Magnaflow, Gibson and MBRP for my needs?
Just go to a shop that's good with exhaust and have them build you the system with exactly what you want and it will be cheaper than a premade system. I had everything from the muffler back removed and had them put in a Flomwaster Super 44 single in/dual out muffler with the 2 tailpipes and 2 black chrome tips. Parts and labor was around $350 and I got exactly what I want so I didn't have to settle for how a premade system is setup. The only difference is that it isn't mandrel bent, but with a daily driver pickup you won't feel the difference. Just make sure to tell them to use stainless tubing.
While having a shop make a system might be cheaper, it wont be better nor will it flow nearly as well as the premade stuff. There are very few shops out there that own or use a mandrel pipe bender, those machines are super expensive and take a lot more time to bend the pipes versus the normal crush bender that most all shops use.
Personally I went with the Magnaflow 12909 (3.5" offset/offset) muffler, cut out the flapper valve and cut out the resonator. Sounds perfect and no drone, cost me $220 installed for everything.
I understand that, but on a daily driver pickup I don't see how you'd know the difference. Especially if you leave everything before the muffler untouched. I just don't see how just mandrel bent tailpipes would make any difference on a daily driver truck. I'm not saying mandrel pipes won't flow better, I just mean that you won't feel the difference especially when the only mandrel pipes are behind the muffler. The only time I would want mandrel bent pipes would be on a performance vehicle and I mean one with tons HP or something that has forced induction.
As for buying a Borla off the shelf that way I think youre out of luck. I will be buying the Dynomax catback below and replacing the muffler. Stainless mandrel bent and 300ish online.
http://www.dynomax.com/single-3-cat-back-system-dynomax-vt-muffler-38531.html
This is a borla mufller with the same pipe diameter and center in/offset out configuration. Is a little shorter so will have to add some straight pipe.
http://www.borla.com/products/proxs_muffler_part__400482.html
This would get you what your looking for though under 500 bucks if you source parts right.
Edit: Here is the install instructions and individual part numbers as well if you didnt want to buy the full Dynomax catback. I found that it was more expensive this way though or close enough that its easier to buy the full catback.
http://www.dynomax.com/downloads/instruction_pdf/38531%20InstRev0115.pdf
Other objection to this is that this was not stainless for that price.
What ever you do don't go with a muffler shop system. They suck ass and look like shit also...spend the coin and get a good mandrel bent system.
RT
I honestly don't even know if they used stainless because I was so eager to just have the exhaust done since you hear nothing (barely at WOT) with the stock exhaust. It does look like it has some sort of coating or maybe they just spray painted it black because when I said what I wanted I said I wanted it black. I was only talking about the tips but I think they thought I meant everything they installed.
RT
Actually the shop that did mine did a good job, they're good with exhaust. And again, someone can buy whatever they want but you won't notice mandrel bent pipes on a daily driver truck especially if you only mess with the muffler on back and not anything before the muffler. The only time I would make sure to get mandrel pipes would be anything with forced induction or just anything high performance. I'm not even going to mention show vehicles because I don't like trailer queens that only go to shows.
what yalls opinion on the stainless works exhaust system?
Most likely mild steel. Coating should help though.
I know to each his own but another big thing for me is resale. You can't recoup any of the cost of those systems with the exception of maybe selling muffler. If you go buy a stainless nice catback you can always resell for 80ish percent of the original cost if you sell truck or revert to stock.
Disclaimer: pulled number out of my ass based on my experience reselling and parts I've seen sell but you get the idea.
Well I know I sure as hell won't go back to stock since I don't want my V8 Silverado sounding like a Prius. I know a premade system is made where you can easily take it off and resell (unless you have it welded), but I plan to keep this truck for as long as it will go down the road so no problem with resale value. Thing is with premade systems is that the company wants to make back any R&D and so on. I'm also picky so I don't want to settle for how a system is laid out, I'd rather just tell the shop what I want and have them do it. Again I'm not the one to tell someone what to do to their own truck, just giving my opinion. Maybe the tailpipes aren't stainless, I really don't know and I know I didn't specify that it had to be stainless and maybe I should have. But again I'll say that I was just eager to have a bad ass sounding truck after not being able to hear the truck whatsoever.
I favor keeping the stock stainless pipes and going with a performance replacement (stainless) muffler (like from Flowmaster). Which is closest in fitment to the (whisper quiet) stainless muffler that is stock on the truck? I really don't like the stock quiet. I prefer a mild performance tone; relatively mild at idle and noticeable when I press the pedal :)
Question: What is up with the 'drone' that some kits such as the Dynomax VT eliminate when dropping 8 to 4 cylinders? I'm not crazy about having a valve inside the muffler... what if it sticks in either position? Is the exhaust tone that annoying when the engine flips 8-to-4-to-8?
Just ordered the Flowmaster Force Two dual exit kit # 817666. Will have the pipes exiting behind both rear wheels. I had a system out the back and want a different duals look. At least it will exit behind the wheel(s) like my single Borla; just behind both wheels. the Flowmaster video on Youtube sealed the deal. Super 50 stainless muffler. Will have local Rainbow Muffler shop in St Pete handle the install.
  • 7 months later...
7-8 months after and the 4-cyl drone and switching 8-4, 4-8 in city traffic is making me use M5 on the trans in stop-and-go and I'm HATING the drone at highway speed when it flips to 4-cyl.
Is it possible to have one of those valves added AFTER the muffler? That is all that I hate about the exhaust system. Don't like the idea of replacing the entire system if I can get a flapper aft-muffler.
Here's what I'm going to do: Have the original exhaust system re-installed WITH Borla Touring Muffler PN # 19131346.
Wish I had done more homework and taken more time. I am hoping I can sell the Flowmaster Force II system USED for at least half what I paid for it to recover the cost of the Borla muffler with install. I just can't stand the 4-cyl drone and don't want to have to use M5 to get around it. I had the OEM system cut in one place so I am hoping I can get it welded/connected again.
Will advise. Not happy :(
    Smitty462
    Smitty462
  • Who's Online   5 Members, 1 Anonymous, 649 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
