2010 denali aftermarket wheel offset
Hello all, I'm new to the forum and probably the second time I've ever posted on any forum. I recently purchased a 2010 1500 sierra denali and would like to buy aftermarket (fuel) wheels. I'm also new to the lifted truck world as well. So my dilemma is that I love the height of the truck but the stance I can't grow to love. I believe it has a 5" lift and also can't seem to find the brand anywhere on any components. Factory control arms and struts, 5" block in the rear with fox 2.0 shocks. Running 35x12.50 on the factory 20" denali wheels. I've done countless research and can't find a front/side view of any denali with aftermarket wheels that stick out about 2" out back. I'd like the front to stick out maybe only another inch. I was also all over customwheeloffsets.com to find the perfect set up, all over google, amd forum searching, and still can't get an answer.
Basically, I want a 20x10 wheel on 35x12.50's only I don't want to spend the money on a set with a -12mm offset and not be satisfied. Should I go -24 with a 4.5" backspacing? Is it going to fit with factory control arms? I really really don't want wheel spacers at all lol. Any help is greatly appreciated
Get 20x10s you will be happy if you want just a little bit of stance, I have 20x10 with -19mm and I like it nothing crazy but it does stick out.
So would a -24 mm offset be about the same if not a little more? Are the rear axles different in the half ton? And would it rub the control arms up front? Cuz im really close to the CA's right now
