Tire pressure monitor sensor
I have one sensor on my 2011 Sierra that is reading about 4-5 psi lower than my tire gauge. I just did some research and found out that these sensors have a battery and are designed to last up to 10 years, but I assume it's possible for one to go bad. Is there an easy way to find out if a sensor is bad?
If you relearn your tire positions and its able to sense each tire i would think the batteries in the sensors would still be ok. My truck wont remember my tire positions ill relearn them it will complete but then my dash just says relearn tire positions GM has reset them 3 times and tells me thats all they can do, but judging by your issue and mine so there must more to it then just a sensor being faulty, probably has something to do with to communication error from the sensors to computer.
Your TPMS sensors should be replaced every 3 to 5 years.
this probably wont help your issue but just to update the issue i was having in case anyone elses truck doesnt show tire pressures, i have the WT version which didnt have the Driver Information Center (4 vertical buttons beside drivers side vent) gm told me they didnt know why my tire pressures wouldnt show on my dash, just installed the DIC now my tire pressures show up as well as MGP and ect. moral of the story GM has no idea what there doing
    • Length/amount of data capture will be important to consider, sifting through 5 minutes of a data log can be enormous when it is stored in milliseconds. Being able to find the 'event' let alone decipher it.   Presumably the driver would notice something and hit a button to capture the 'window' of data. That window has to be large enough for the operator to recognize the event and react accordingly.    The data has to be able to be retrieved easily.   The data has to be able to be understood. Which is the biggest challenge, dealer techs won't even know what most of it is and would likely not even look at it if an owner brought it to them. Meaning the owner, the least educated/qualified, trying to understand it.    How will the data be presented? Could specific PIDs be selected and a timelapse graph be watched? How will a specific value be noted as abnormal? Additionally, a good data logger would be able to 'learn' normal values for a specific vehicle and flag abnormalities automatically. It could in theory watch parameters degrade over time and suggest maintenance as needed. (If the MAF reading begins tapering off for a given set of other readings - MAP, throttle position, Ambient, etc.. a flag to check air filter.) With the amount of data available, a device (really the vehicle rather than an additional accessory) should be able to do more than issue a DTC. It should be able to run the full diagnostic suite automatically and present a solution rather than a code. (It's not the 90's anymore). The technology is available for the vehicle to not just say "P0087", it should know low fuel pressure, check other PIDs to narrow down the problem itself, and determine if it is a lift pump, high pressure pump, regulator, leak in the fuel line, clogged filter, etc. Even if it can't narrow it down, it should be able to guide the user to the likely problems.   This would be a major problem for dealer service departments, which are the manufacturers customers it is in their collective best interest to NOT have this available to the consumer.   Further, if the owner is going to be the primary consumer of the data, it's got to be at a consumer price point vs. dealer only specialty tool price.   This group is more 'involved' in their vehicle than general public/consumer and will have knowledge, experience, needs and desires that are quite different from the market at large.
    • I put the prof up. If you read what I posted. You can see that housing, cars and income are in line with the era we were talking about. It’s harder in some places easier in others. Let’s agree to disagree and put this back on track, OK? We both are pretty stubborn and hard headed. But I bring receipts. If you wish I will not respond to you in the future.
    • Lets see if I can sum up two pages of nothing useful.    You want to refute your own governments data of the "Purchasing Power" Index FOR THE ENTIRE USA and its territories replacing it with the experience of a single family and its business and label that reality?  Then pound on that for a week hoping it will find traction?    Stan, I've told you several times. I don't do irrational. There are more people in the USA than your family.    I'm pretty sure this tread is so blown up. I'll give you a few days or months if need be to post yourself silent then I'll see if I can find enough parts of the train to reassemble it.
    • Facebook groups hate VSE, poor customer service; their responses to criticisms are pretty poor for a reputable company. I'm not a customer, haven't bought anything from them, but how they handle themselves on social media is a definite "No" for me.
    • $10,000 for a transmission?   Pretty sure I could buy all the parts, tools, and education to rebuild it myself for a quarter of that amount.   or swap it out with a new one...
