Muffler Delete on 2016 Sierra
gmyeah
All, I know this topic has been killed before, but I did a ton of research and thought I was doing the right thing with a muffler delete(leave flapper in where it was) to get a little sound so I wouldn't get drone or that chopper sound. So the sound is pretty good, but man....you get around that 1500rpm range when going a slow speed and it's crazy noticeable. The delete was just a piece of aluminized exhaust pipe replacing where the muffler was. It sounds sick (in a bad way) at that low speed/low rpm/v4 mode.
any thoughts, do I revert back to the stock exhaust or get a afm delete module you plug into the truck to deactivate the v4 mode? I actually tried keeping the rpms up a bit....and putting it into manual, but it still sounds pretty bad, so not sure if that would even work?
1500 gmc sierra sle 2016
  • 2 months later...
Just had the muffler delete done. Piped everything after the 3rd Cat and sounds awesome. Drone in V4 mode is my only complaint.
i got the Diablo tuner and removed the V4 mode. makes the truck drive SO MUCH better!
Muffler and resonator. Emeryz28 good to hear thats my next move!
manually shift m put in 5th gear no more drone
Just went and did this today. Removed flapper and muffler, kept resonator. I do hear the V4 noise but it's alright so far. Worst case is a tune to turn it off.
    Fishboat
    Fishboat
  • Who's Online   2 Members, 0 Anonymous, 521 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
