Airlift 5000
Put it to good use today. Had to get rid of a ton of brick,Belgium blocks and concrete. Loaded up truck, leveled out automatically. Went to scale and could have sworn he said i weighed 9100 lbs. My truck is a 14 cc standard bed high country.
Truck drove awsome. Felt the load but she took it, now i figured i was at 2000 to 2300 lbs with passanger. But from the scale i was close to about 3000. Does that sound right?.
No issues stopping, driving even engine temp was normal. I do have intake and run e85 but doubt that would matter.
Sent from my SM-G900P using Tapatalk
The bags are amazing, aren't they? The way they allow the truck to handle safely and ride well when loaded--even heavily--makes the truck so much more useful for actually being used as a truck. That said, I wouldn't recommend putting too many miles on at 9100 GVW....your axle bearings, etc, probably will wear quickly. But it's nice to know you can if you need to in a pinch.
Do you have a self-leveling system? If so, which one and how do you like it?
I love my set of air lifters! Makes life a lot more comfortable towing heavy. I was genuinely surprused at how much a difference they have made in towing. They're are probably close to the top in regards to the upgrades I have done - makes handling much more stable at the upper end of the tow range.
I've been looking at upgrading from manual fill to one of the in cab wireless controllers. So far it seems like etrailer seems to be the most competitive in pricing. However, I would really like to pick and choose the components so that I could get a medium cycle compressor and a small air tank without purchasing stuff I don't need or getting raped on pricing.
I have smart air self level. Love it. It adjusts automatically.yeah didnt think i was that much over but i was lol. Doubt i will ever be that loaded again.
I'm glad it's working well for you. Do you have it set up with a single sensor or dual? Do you find the pump coming on all the time when driving offroad, etc? I'm curious how well it works mainly for the sake of others--I cobbled together my own mechanical system but not many are that ambitious so if this system works well with few downsides it could be a good option for many people.
It may have been just bad luck or the fact I go offroad a lot (mud, water, etc) but I went through two different wireless control systems eventually having both of them die on me. That experience made me fond of direct connections and the ability to mechanically override a system if/when it dies and wary of any system that relies on wireless pressure sensors to control things (the Smartlevel does not).
John - Good point about the wireless systems! I don't off road but could see durability being an issue down the road. I'm definitely not opposed to cobbling together a system myself. Heck I've already built and installed an aux. power distribution system installed (6 relays, 2 fused), why not a home brew compressor control system.
You make a very good point about having a manual override (dump/fill) option. Any chance you would be willing to share a bit more about your system? I can't remember seeing a thread about it. As I said, one of the reasons I was looking at wireless was due a dislike of running wires into the cab. To be honest, I can live with that issue. The real pain for me thus far has been trying to find a decent looking in cab control panel and mounting location. At leas with the wireless units they are digital and relatively unobtrusive. If I went wired I'd like to do a pillar pod mount but I have yet to see one and I would think that it would create problems with the pillar airbags.
I have the single stage. It goes on when a load is in the bed. It does on occasion go on when the truck is angled in the driveway, but its has to be a pretty steep angle.
How do these kits hold up over time as far as getting covered in salt in the winter and rubber dryrotting? ive wanted a system since i got the truck but havent pulled the trigger. every time i load the truck i hem and haw between an air lift system or an add a leaf
Go with bags! I had bags on my 3/4 ton for over 3 years and the bags still looked new when I took them off when I got the new pickup. I also live in SD where we have crappy winters with salt and gravel put on the roads.
Yes, I've been meaning to write a thread about it but just never got around to it. I'll try and gather up all the part numbers and various pics I took over the next week or so and put up a thread. It's nothing complicated, it sounds like it would be cake for you.
That's good to know. It sounds like a good system. I suppose there's no reason one couldn't simply wire a switch at the power source to "kill" the system for rock crawling purposes. I eventually put a on/off solonoid on my system for that reason but a simple power switch should be easier for anybody who wants that capability.
They're very durable. They're pretty much all made by Firestone using the same bladder-type design they use for the big rigs. I don't think I've ever heard of one failing that wasn't damaged by something physically poking a hole in it or being pulled apart by somebody with a lift (there's a fix for that too for lifted folks).
All you would have to do is put it on a switched 12v, tap off of ine of the upfitter switches. I grabbed a switched 12v ignition
    • It's possible the two trucks are using different body control modules which is why yours works and the OP's doesn't.   So much in these newer vehicles depends on model/trim configurations, production date. They don't all use the same modules like back in the day.
    • I forgot to answer the question as per what market mine is set to and yes I finally found that area on mine and yes its also set to America.   So here's something I realized as I wasn't looking at that part in the Sierra section until now, your right that what I see here as choice 3 under Sierra which says 07/2023-06/2026 ( 433 MHz 13542523 ) it has no choice 5 for tire pressure selection. Where as it does under the Chev choice. However I kept going down the list within the Sierra and I am really wondering if choice 9 will work for your truck as it has the same model number and hertz sensor as my truck. I would say try that choice first, if that doesn't work then jump over to the Chev section and again choose that same model and hertz choice as for some reason the Chev section gives the choice 5 of tire type/pressure selection for going back a number of years. Could very well be an Autel thing that they just didn't get the updates all done properly under Sierra but anyway first try that selection 9 I suggested under Sierra and then go from there.
    • Looking for this piece that holds the hose clamp in place. I have the hose clamp just not that other piece. Dealers and wrecking yards in my area will not sell just that piece. They want you to buy the whole air tube $100 +/- to get that $5 part.  that piece isn't molded to the air tube as I looked at my friends truck. It's held on by a screw and nut. I'm trying to put the OEM parts on the truck as the previous owner butchered things up installing an aftermarket CAI. It really looked homemade. 🤣 Thanks
    • Ok I missed that part that yours is a GM. The strange part is that the choice for year ranges and within the year of 2026 is different on the Sierra then on the Chev for some reason as I am looking at my tool at the Sierra choices. Now I am guessing you see as to your sensor part number as it may be different on your truck for some reason and a call to GM should get you the part model number of the sensors you should have as well as which MHz your sensors are. I know mine are the ones as per what I listed but there are other choices in the Autel and got me wondering if by some chance they put different ones in your truck. Having said that, did you try using each of the choices starting from No 1 and going on down the list, not sure if that would mean shutting off the engine each time and resetting the tool and going at it again each time. Also I thought of something else which may sound retarded but if there was some stupid chance that the chev choice would work. The reason I say that is that the Sierra is showing a range up to 06/2026 for the various choices of sensors it could be where as the Chev has one choice that has that 12/2026. By the way it is possible to not run the truck and you may know that as per not pressing the brake but pressing and holding the start button for a few seconds and it lights up the dash ( its called service mode ) but that sucks battery power and if it were me doing it that way I would be throwing on a decent sized battery charger before doing it that way as killing your battery won't make you happy at me at all !.    Like I say, just a thought to try the Chev choices if you have already exhausted the Sierra choices but first it would be nice to know for sure what exact sensor model and hertz your truck uses as I assume only those choices that mention the sensor would work unless a choice that does not mention the sensor model would somehow work. Its frustrating when one is trying to use tools like this without the experience of the tool and the vehicle, as I am sure dealer techs themselves struggle with it when starting out or a new model year comes along that is slightly different.
    • I tried before I updated the scan tool just incase an update messed it up, but it never worked so I updated the scan tool and it still didn't work.   Only difference is I click on Sierra not Chevrolet cause I have a Sierra.   If I click on 2026-2024 I didn't have any option to change placard, when I click on 2023 it does give me the option but when I try to do it,.it says vehicle not supported!   I have my region or market or whatever it is set to America I think, is that what yours is set to?
