Trailer blinkers 2014 1500 not working
edktm
So I have a 2014 Sierra crew cab. and I noticed last fall my blinkers were not working on my brand new trailer.
Today I checked the receptacle with a lighted trailer tester and no lights came on when I used the blinkers or the flasher.
I looked thru the blogs but nothing.. Running lights work...
Check the fuses under the hood. I had a problem with my trailer tail lights not working, but the brake lights did. Turned out to be a fuse. Also, plugging in a trailer while your truck is on will sometimes cause a fuse to blow so I always turn mine off now.
I have the same issue on my 2014 Sierra. Are you using the four pin or seven pin connection? Mine works using a seven pin to for pin converter, but not using the four pin connector on the truck. I an on my second time having the dealer replace the fuses.
Sent from my SM-G900V using Tapatalk
Usually it is the grounding issue. New trailer or not, does it have the grounding wire connected to the trailer frame properly?
I had the same problem. Check your fuse box. I believe its number 15 and 17
    • *Your
    • I'd guess that it's because they are Mann-Hummel filters since about 2016, they own Wix and are mostly all made in China now.
