Airaid MIT
Just ordered the Airaid MIT and a K&N stock replacement filter. Saved $50-100 over the full CAI which I don't like the open element of the CAI filter due to temperature. Plus I've read here that the stock box does just fine. :)
Can't wait to hear the growl of the 5.3L once I install it!
Once you get in installed, could you post how you like it? I'm thinking of getting the same set up.
thanks.
I have that set up with a green filter. Sounds good at times. Sounds good at lower rpm, then gets oddly quiet past a certion rpm under moderate/normal acc. Under harder acc. it sounds decent.
thanks.
Will do! I watched the video on the full K&N CAI and loved the roar the 5.3L did at full throttle but I just don't like the idea of an open element. Hopefully this will give me a similar sound.
I have it on my truck. I honestly didn't notice any sound difference, but I already had my Corsa exhaust at that point. For aesthetics though, the MIT looks 100x better in the engine bay.
Just an FYI. After you put a few miles on the MIT, check your intake tube for oil. I had an issue accumulating oil in the intake from the two breathers on the valve covers. Ended up installing a clean side separator, and the issue went away.
Thanks guys! For those with this or similar setups, how about any notice in improved throttle response and slight power gains? I'm not looking to add a CAI or exhaust.
What this with or without a catch can? I installed the MIT and catch can within a week of eachother. I am hoping I can cut down oil in the intake.
I had a catch can before and after. The clean side separator is a totally different piece.
Catch can will keep oil out of the intake manifold. Clean Side separator will keep oil out of the intake tube.
Got it installed. You definitely hear more of a low groan between 2-3k RPM. It seems to accelerate quicker but that is most likely in my head. Engine now sounds like a V8 both out and inside.
I have the same MIT and it does improve throttle response in my opinion. It does sound good and makes the Flowmaster sound even better.
Sent From My Galaxy S6 Edge+
    • Thanks for response. Leak was right under drivers seat or thereabout.   Had checked by other mechanics and have read other information.   The solution can be a tad complicated and replacing multiple parts And with some.  The issue was still the same.   The brakes do work.   Just that the pedal is softer and goes further down.  But the brakes do work.
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
