Darn Regional Incentives
RyanbabZ71
Ok as many of you know i am looking for a work truck. Well this has to be the most stressful time of my life thusfar (and i just graduated college that was apiece of cake).
I read in the newspaper today that gm annouced added incentives for the midwest. They are now at $4K for the silverados (up from 3K) HOWEVER the paper didnt state it is only for southern indiana (you have to have it registered there) and is not good for the chicagoland area. Bunch of BS
I have to vent
Plus there are no arrival blue trucks like what i want out there (found one close)
new job at a steel mill
dont wanna beat up my truck (like today busted windshield driving the roads i will be driving everyday)
I'd be pissed too. Sorry to hear about the windshield too. I know I took a stone to the hood 1 day that left a nice nick/dent. Frosted me big time when it happened.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
