Inside door rust issue
So when you open your driver door, there is a piece of rubber on the trim of the truck body. I realized this rubber has torn in a spot and has let water sit in there and begin to rot out the body under the rubber. I was wondering if anyone else has this issue and or what to do about it? I guess I could rip the rubber out and see how bad it gets or is there a way to seal it as it is with minimal cosmetics?
So its just the weather stripping, and for those who havent realized theirs is rusted too once you look, i have links for you to save hundreds..
http://www.gmpartsdirect.com/chevrolet/silverado-1500/22766417/2010-year/lt-trim/5-3l-v8-flex-engine/body-cat/uniside-scat/?part_name=surround-w-strip
http://www.gmpartsdirect.com/chevrolet/silverado-1500/22766400/2010-year/lt-trim/5-3l-v8-flex-engine/body-cat/uniside-scat/?part_name=surround-w-strip
Peel up your stripping at the split point and take a look!
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
