Have any of you guys had an issue with moisture in these LEDs? I’ve seen that desiccant packs work well in the non-LEDs, can the turn signal socket be removed and a desiccant pack put in? Otherwise these are sealed units...
  • 1 month later...
  • 1 month later...
On 5/31/2019 at 12:16 PM, 2SSRS said:
Guys we have two sets of the LED headlights and tail lights for sale there NEW in the box at a good price let us know if you like a set.
are these still available?
we have 1 set of headlights only and there blems, call us up we can send pics.
  • 9 months later...
Ok here goes, first off you all know the way you control LED'S right? there turned on and off 100 time a second, if you have a movie camera on your cell record when your DRLs are on, then play back and watch your lights flicker, now there is a tolerances on all DC power so what you may have is a car harness that is off more then the outer side, and yes there is a volt spike on the turn signal too.send him a harness that has a cap on that side too.
I know this is an old thread but do you know what size type of capacitor I should tap into my drl wire?
The drl cutoff circuit is intermittently not working and I’m going to remove it and just go back to straight harness. The drl doesn’t come back on after using the turn signal and I tried replacing the resistor and relay. Just going to remove it I prefer the drl staying on with the turn signal just world like to try fixed the flickering strobing drl on the cold start.
On 5/17/2016 at 6:01 AM, zmnypit said:
Sorry I'm a little late, I've been in the Caribbean for a little over a week and just getting around to posting pictures. I know there was a lot of fuss of whether or not the SLT lights would so I bit the bullet and bought a used set to test. I got the lights and with the help of a fried who owns a 16 and you guys providing a pin out I was able to get the light working. The only issue I found was the DRL did not cut off when the turn signal was activated. Some may like this some may not. I however do not. When the sun is out full force and the DRL is at full brightness the LED turn signal is a little faint. Plus i'm picky and would like to stay close as factory options as possible. With all that being said I figured a switchback circuit inline with the adapter would cut the DRL off once the turn signal got power. Only problem is I have no clue how to build one so I reached out to GEN5 and they were more than helpful. I sent my light to Jarrod a little over 2.5 months ago and the process of building a harness began. For you guys that already have the SLT lights you can thank me later, JK. Anyways the harness for the 14-15 SLT is still being tweaked as its different from the SLE's but here you go.
Still have a couple kinks to work out but they work. Switchback circuit is being. No biggie Offer is on it as we speak.
SLT lights part numbers:
23506752k
23506752
23506753
Hey nice build. I was wondering where you got the harness, I am thinking about doing this upgrade to my truck.
The harness
One of the issues
Out with the old in with the new
Things were a little dirty so what better time to pressure wash
We have some light
Headlights work, thats a plus
all done for now
e23506753
The harness
On 5/17/2016 at 1:06 PM, Arth said:
Here for info. Really wish I had LKQ connections!
One of the issues
We have some light
all done for now
  • 5 months later...
Alright guys I have a couple sets of headlight (need to verify how many exactly) adapters left then that's all for now. Life has been so busy its a balancing act as of lately so probably wont be building anymore anytime soon. I will add a list below of all parts needed for anyone looking to this this themselves. All parts can be ordered through Mouser or Waytek and try to answer any questions.
Headlight adapters:
Old side (14-15)
38383 - Male Connector OEM part # 15326655
30472 - 20ga Male Terminals OEM part # 15304730
39036 - Yellow cable seal OEM part # 15366066
39039 - White cavity plug OEM part # 15305170
New Light side (16-18)
38411- Molex MX150 female connector OEM part # 33472-0801
30096 - Male terminal - OEM part # 3300-1002
Uxcell 10pcs 16v 4700uF capacitors (amazon)
20ga wire
50w 6ohm resistors (amazon)
1/2" wire loom
solder
Wire schematic:
new light:
BK - Ground
YE - Low Beam
WH - High Beam
VT/GY - Parking Lamp
D-BU/WH - Turn Signal
GY/D-BU - DRL
Old light:
BK - Ground
YE - Low Beam
WH - High Beam
VT/GY - Parking lamp
GY-D-BU - DRL
I'm not going to post a full detailed how to but basically you need roughly 12" of each wire then pin them in the correct slots. You can find the schematics on gmupfitter for the pin slots. The capacitor will go between the low beam and ground and the resistor between the turn signal and ground.
If you plan on cutting the factory plug for the new one all you will need is the capacitor, resistor, new plug and the terminals.
  • 1 year later...
If anyone is interested I found a complete set cleaning up my basement yesterday evening. Can ship out at lunch just PM me. This is the last set I will have. $90 shipped
Thanks!
Edited by zmnypit
  • 1 year later...
Hello everyone,
Can someone tell me how to get in touch with zmnypit? I made a harness by his method but can't get the low beams to c ome on correctly.
7 hours ago, vu337 said:
Hello everyone,
He hasn't been back for over a year now. You might try starting a private conversation with him and maybe you will get lucky.
    CaptainDad
    CaptainDad
  • Who's Online   2 Members, 0 Anonymous, 598 Guests (See full list)
