Bracket for airbag air hoses
I ordered a set of Airlift airbags and plan on installing them this weekend. When I was researching I came across a bracket that mounts under the bumper for the air hoses.
I know I can drill holes and replace my license plate screws but I like the idea of the bracket under the bumper. Does anybody know what I'm talking about or seen this? Depending on how much it is I will buy it or use it as a guide to make my own. If I make my own I mainly want to see it to see how it mounts.
I've tried searching but can't find the thing again.
I have installed air bag kits on 3 different silverados, I wouldn't hang them below the bumper IMO. There more likely to get scraped off of damaged. Just my thoughts. There a good addition to your truck.
Where did you put your's at? I might eventually get a compressor but for now I'll inflate them manually.
I don't do any off-roading so the chance of them getting hit is slim. The only "off-road" I do is going to the deer camp and it's through grass fields and gravel roads.
I just use one air line and put a T fitting ran it up put it behind the gas cap. I just found it easier to flip the gas cap open check the air pressure close it up. I just didn't need to have 2 separate lines for my use. Just where ever you feel like will be easy access and protected a bit. The bracket would be fine like you said where your going and I fill mine manually to. There a neat upgrade to keep your truck level with a load in the bed.
How did the t-fitting affect the airbags? I've read that it will cause air to transfer side-to-side when cornering. Also, the dual lines are more for uneven loads like a slide in camper, etc. For me, I never haul anything that uneven and will mostly be for towing a trailer so I don't think the t-fitting will have that much of an affect on handling.
I'd rather have it through a t-fitting anyways. I wish I had bought one at the same time as the airbags so I'll have to install them with the dual lines and then get the t-fitting later.
The T fitting works fine, Ive never had a leak or anything like shifting. I dont have uneven loads either so I didnt need 2 different lines. Less complicated for me just air up and there always both the same height. I do use a different brand than your Firestone airbags but there probably both look the same anyway.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
