Reprogramming Speedometer?
if you get the right programmer, it not only fixes the speedo, but also your shift points etc to accommodate the difference.
is that something the dealer can do or does it need to be done by someone that specializes in it?
From my understanding, most dealers don't like to mess or won't mess with reprogramming because you changed the stock wheel or tire size out.
Is it something a local shop may have? Seems stupid to spend 300+ on a programmer to reprogram it one time ...
Programmer. It makes a backup of your original ECM data, then changes what it needs to. if you ever need to revert back, it has the data stored in it to do so. Once it makes the backup and changes your ECM to the new settings. The programmer is locked to the vehicle, so this isn't something a local shop could do. Your two choices are a programmer, or find a dealer that is willing to reprogram your ecm.
Thanks for explaining. How necessary do you think this is? I'm about to get some 33" tires (32.8 to be exact) whereas the stocks are 32"... new tires are much wider though too
CAN'T
Lauras gmc puts 33x12.5 on their leveled trucks and they advertise they don't recalibrate for that size but will once they go above 34. I put 1in taller tire on my truck and via gps when my truck says 70 im about 73. Hope that helps. I did not do a programmer on my truck.
It depends on how much different they are I put on Goodyear Duratrac's and it only changed by 1/2 a mph so not even worth bothering for me.
Just FYI the gauges round it up so by the gauges it states 55 when in reality I'm going 54.5.
I have a good navigation GPS that shows decimal places. My actual tom Tom GPS wil show 54 to the 55 by the gauges.
I find the rounding little funny,
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 768 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
