Cold start
About a month ago, my crank position sensor quit on me and left me sit. After popping a new one in, it seems like it is taking a little longer to start up on a cold start. I mean it doesn't take long, but it used to be instant. Now it cranks for just a little bit before starting. On a cold start I always let the fuel pump prime, and I just replaced the battery about a month ago. Any ideas? I'm not saying anything is wrong, just wondering what may have caused this.
Is it a Delco branded sensor that you replaced it with? Also how old is the vehicle battery?
Ok. My thinking on this is that different branded crank sensors will have different parameters in which they measure, which will in turn result in a different reading being sent to the ECM and thus the longer (or sometimes shorter) crank cycle, depending upon the model of the sensor. Is it just a half a second longer or drastically longer cranking? If it's not too long I wouldn't be worried. The old 4.0L inline 6 that was famous in the Jeeps from the 80s and 90s would crank for almost 3 full seconds, sometimes longer. And then there was my 99 Silverado which would only need 1 second every time. Except for when the battery got low or worn out.
Ok thanks. And yes it's just a half a second longer than normal. I'm just real picky about my truck, so it's something I noticed. Thanks again!
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
