Check this out:
Wingnut
Posed pic, and some photoshopping. Look closely at the bend in the hood and you can see the jagged lines of where the person just painted a black "bend" they didn't use enough anti-aliasing to mask it. :thumbs:
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 832 Guests (See full list)
