Brake pad replacement
What's everyone using to replace their brake pads? I have to replace mine soon and found a bunch of them on realtruck.com but with so many different choices not sure what is best, or just go to an auto store?
Rock Auto should list some as OEM replacement. :happysad:
I have used both AcDelco and off-brand. It depends on how long you are planning on keeping the truck. I put off-brand on my 07 because it needed brakes badly, but I knew I was going to be buying a new truck within a year so I didn't care about them being long lasting. I figured I would save my money.
I plan to go EBC Yellowstuff. If I had larger wheels/tires, I'd go Orangestuff (also known as extra duty). Since I'm stock, and I don't really need the additional performance, I'll save that cash and go yellow.
Really can't go wrong w/ EBC. A tad bit pricey, but good, good stuff. Honestly, I wish they weren't color coded though. Yellow pads look fine on a Porsche GT3, but out of place on a grey GMC half ton imho.
I just rolled 59,000 miles this past week. Had my wheels off for rotation, and my pads look like I could easily get another 59,000 from them.
When are others changing theirs out?
I'm planning going with EBC 7000 green stuff and either the slotted and dimpled or carbon blade rotors. The yellow stuff seems to me like it's too much of a race compound. I had stop tech big brakes and street/race pads on my last truck and I'm not a fan of that stuff. The 7000 green stuff is longer lasting and lowest dusting I believe and still maintain a great friction coefficient. Extra duty (orange stuff is full race) might be a good choice too if you're doing serious towing/ hauling.
Baer makes an eradispeed kit with larger diameter rotors and brackets that push the factory calipers out an inch or so to be used with the oversized rotors. But there's nothing out for the newer trucks yet. That would be a great upgrade
    bellssn690
    bellssn690
  • Who's Online   1 Member, 0 Anonymous, 804 Guests (See full list)
    • This is a really late reply but I just found this thread. They won't sell the hinges. I've gone 7 rounds with them. Their solution is to buy a new cover. I'm about to buy a new cover and it won't be a Bakflip. It also won't be from realtruck.com.
    • Yes, and also pulling heavy trailers or a large camper up steep grades as well as descending grades such as the more rustic off road camping locations and using engine braking with that low gearing as well as soft ground can just suck the power . I realize pickups these days tend to have an over all lower first gear ratio compared to automatic transmission pickups from years back so that has helped a lot in its ability in high range but there comes a point if in four wheel drive the torque runs out at the wheels, certainly with a gas engine. They don't put two speed transfer cases on pickups for a cool factor, they have a function if one needs that massive torque to the wheels that high range can't deliver.
