95 Sierra 1500 Wont Start
Hi all, I'm new to this forum so thanks to all for the help to come...
I just purchased a GMC 1500 Sierra with a 5.0 engine. I put new muffler and exhaust pipe on it over the weekend.
Today while driving and sitting at a stop light, the engine started idling roughly, 800rpm to 100 and back and forth for about 2 minutes. The truck then died. I have plenty of battery and gas. The engines turns overs nicely, but I don't seem to smell any gas. When I look into the carb I don't see or hear any gas when the peddle is pushed.
Can anyone please point me in some direction? It's sitting in a public lot and I need to get it towed or fixed quickly.
Thanks
1995's do not have a carb, they are TBI. Test for fuel pressure. You can spray starting fluid down the throttle body to make sure its not an electrical issue. If it tries to run, its fuel related.
fuel pump relay or fuel pump amd its associated wiring
I replaced the fuel pump relay and was going to replace the fuel filter. However the fuel filter appears to be the original and was rust welded to the fuel line. The truck was parked illegally in a lot so I had to have it towed to a service center. Once they tell me the problem, I will either have them fix it (depends upon cost) or do it myself. I am fairly handy and believe it's the fuel pump as I didn't hear the pump when I turned on the ignition switch. However, where it was parked I didn't have the luxury of time to work on it any longer. How long should it take to remove the old fuel tank and replace the tank and fuel pump. I will probably replace the pump and tank together if it's the fuel pump.
Thanks
Easy way to change the pump is to remove the bed. Couple of hours at the most for you and a friend or two. Dropping the tank is a PITA if you are doing it with fuel in it and laying on your back in the driveway.
    JJ_Denali2020
    JJ_Denali2020
  • Who's Online   1 Member, 0 Anonymous, 729 Guests (See full list)
