Hey All! new to the forum, and new to the Chevy community, but I'm stoked to be a part of it. I just purchased a brand new 2016 Silverado LT w/ the Z71 package.
I have plans to do a few tasteful upgrades to this beauty, but run into a few "issues" which are more so questions.
the main question that i have is in regards to a 2.5 inch leveling kit, and a more aggressive tire on the stock 18s (probably somewhere around a 33"-34")
I want to preface by saying I work in a downtown area, and park daily in a parking garage. The height limit that is shown within the parking garage is 7" maximum, which scares me a little on my decision......
Good ole google says that the stock height of the '16 silverado is "73.5 to 74.17".
Now to my question - with my truck being that size stock, would a leveling kit and larger tires potentially put me over that 84" (7 ft) threshold? It is absolutely crucial to me that i do not exceed that, as if i do, i will no longer have a place to park going to work...... :(The case of the antenna possibly hitting is totally fine, i just want to make sure the top of my truck will not scrape anything.....
I am hoping someone has a leveled 2016 with tires that can provide me with some measurements.....ground to roof of course
Thanks guys!
If you are looking at a 2.5 inch leveling kit with 33-34 inch tires, you have nothing to worry about clearing an 84 inch parking deck. You will end up around 76-78 inches. I have a four inch lift with 33's on my truck and I clear the parking garage at work which is 84 inches by three inches. My onstar antenna is at 81 inches.
A search would have answered that, but if that is too difficult then a little common sense math should do that trick. Lets say you are at 74" + 2.5 = 76.5". Now the stock tires are about 31.5, so if you go up to a 33.5 you gain half that in overall height increase. So the 2 inch tire difference allows for a 1 inch gain in height. So 76.5 + 1 = 77.5 which is (84-77.5) 6.5" less than 84". You are good. There are people with 4 inch lifts and 35's still getting in their 7 foot garages with a little room to spare.
Tyler
Thanks guys!
Welcome to the forum and congratulations on your new truck! This is a great forum to research and to ask questions. Sometimes you'll receive an off-putting response but most members appreciate the opportunity to help. I agree with the others that you will be fine fitting within the 7' limit and encourage you to continue to tap into the vast knowledge base on this forum!
Thanks guys! The information is much appreciated. :thumbs:
I used to be all over jeep forums, as I was (and still am) a huge Jeep enthusiast, so i know that there is absolutely no shortage of off-putting, pompous responses haha.
Again, thanks for the verification guys.
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 914 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
