Omar1's 2016 Silverado High Country 6.2L
Omar1
Hello everyone, I'm not new to GM vehicles and actually I found my self a loyal buyer. all my trucks were GM made. however this is the first time I bought a high luxury trim.
first thing I have done is installing a cover for the center console. it's really comfy.
Second thing is removing side badges, every badge on the car except the front and rear black bowties which I already installed. As well tinted the top quarter of the front window.
I also installed Bakflip VP bed cover and looks nice on my truck. the only disadvantage is when I want to close the cover, I need to open the tailgate door! which is not practical enough especially when I lock my vehicle.
Here is a list of what I bought:
1: Armrest cover from Ebay the user is: cassina177
2: Steadfast 14-inch antenna P/N 10209
3: DiabloSport T1000 Trinity
Was in Qatar for a short period a couple of months ago. That's a beautiful truck and look forward to seeing what all you do to it.
The headliner and A pillars are light brown, the seats are a dark brown, the dash is another shade of brown, and with a light wood grain in the center console?
Sent from my SM-G360V using Tapatalk
Welcome! Nice truck!
Thanks man,
well I have done a little so far but I will keep you in touch with the new mods.
Love the interior on the High Country trucks!!
Thanks m8
How do you like the 6.2L? I have it in my 14 High Country brownstone color. I love it!
the 6.2L with 8 speed is fabulous, smooth and powerful, most of my friends saying it feels like you're riding a luxury sedan.
This is all stock from high country trim, I just installed the driver assist handle :)
10 Horns installation. well this was tricky used the factory horn relay as only trigger not drawing amps from it because it can't handle the draw of 10 horns! the horns are (2 Stock horns tune + 4 note old gm caddilac horns + FIAMM 2 tone horns (which is the best) + 2 tones stabel horns) I made a horn switch under the hood alwys ON now :D it connects the 6 horns with the 4 old gm horns because they draw lots of amps.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
