Bed Lights tied to Keyless Entry?????
Is there anyway to make it so that when I hit the Unlock button on my key less remote that is turns on my factory bed lights? Would really love to be able to utilize them under my cover. in theory, with all the computers on these trucks, it seems like a simple programing fix. Has anyone tried this?
On my 2011 I wired the step lights to the trailer backup circuit so if it's dark out they light when the doors are unlocked.
Mike
There is no simple "programming fix" on these trucks. There are a couple people in the entire USA that can program the BCM in these trucks.
Try leaving the Bed Light / Cargo Light switch in the "On" position....it will also light up when in Reverse.....not sure if this is the answer, but noticed mine was on this morning when I shut the truck down and got something out of the bed.
Maybe there's a way to run a jumper (diode) similar to the Fog light High beam mod. You'd just have to find the locations for the jumper (Maybe).
It can be done. You use a diode to jumper two pins. I love having mine light up at night. Let me see if I can find the pic.
Jumper diodes, until you mess up and have electrical issues and the dealer and GM void your entire electrical system warranty. One member has already been caught with a BCM with a diode, BCM was friend and dealer and GM refused his repairs.
Hundreds of guys have ran this with zero issues. It was a fluke and he said that the dealer even said they weren't sure it caused it. GM just wants something to use as an excuse not to fix it.
This is one reason I won't do any real mods till after a year or so. Generally, faulty equipment will show up sooner rather than later. Notice I said generally. :rolleyes:
    Policeoff01
    Policeoff01
  • Who's Online   5 Members, 1 Anonymous, 746 Guests (See full list)
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
