adding 2016 radio (projection) in and 2015
I was wondering if anyone has read anything on putting the 2016 IO5 radio in and 2015. I would like the projection function on my 2015. I know GM has started to put the 2015 IO5 radios in the 2016 because they have a constraint on 2016 radio. Any ideas?
There is a vendor on this forum that sells an upgrade kit. Its around $1100. The username is MVI Inc, and they guys name is Anthony Brush.
Check this thread:
http://www.gm-trucks.com/forums/topic/184124-vendor-mvi-apple-carplay-android-auto-updates/?hl=anthony+brush
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
