Hesitation when starting after sitting
GasHog369
So the last month or 2 i have a slight Hesitation when my truck starts after sitting for 10 + hours.. It starts right away but slowly brings the RPMS up. Whenever ive had an issue like this in the past with my old 06 silverado, I would put some fuel injector cleaner in there and it would clear it up.
In the owners manual they say not to use any additives with a flex fuel engine. When i first bought this 4 years ago i experimented with E85, didnt like it and have been running 89 Ethanol free for about 2.5 years.
Since I am not using E85 can i put some lucas or seafoam in there to try nd clean it up or is there a different product out there that is more recommended?
Also any other ideas on what this could be other than a dirty injector?
I just got a Synthetic oil change yesterday so i know thats clean.
Update...
Took the intake tube off the throttle body today and cleaned it out real good with throttle body cleaner. Also washed and oiled the K&N filter. Both were filthy. Started it up after it was sitting for about 8 hours and it sounded a lot better.
Still want to run some sort of injector cleaner thru it if possible.
I was gonna say it could be a low fuel pressure issue, but looks like you've got it straightened out there. Maybe blast out the MAF with cleaner too while you're in there.
What kind of cleaner? Throttle body as well or is there a special cleaner for it.
I hear there's a special cleaner for it. MAF cleaner in a can. I just use acetone in a Sure-Shot.
I ended up getting a can of CRC 1 tank renew. Injector cleaner all in one fix for HP and mileage.
I put it in right away and will continue to drive and post my results.
    bellssn690
    bellssn690
  • Who's Online   6 Members, 0 Anonymous, 805 Guests (See full list)
