17 years gone.
rrsob
After 17+ years as a Master Control Operator at a local CBS affiliate my job is going to be farmed out. The son of the owner of the local NBC station bought us (CBS affiliate) and are merging many of the Dept.'s including mine (Eng. Dept.)
And with the more relaxed FCC rules it's going to get worse. The good thing is if they need someone at the NBC affiliate I have 12 months recall.
Until then I'll be looking for work in the Maintanance Field or back to my original roots: Welding. (use to be a Tig,Stick,Flux Core,Mig and Sub Arc welder). Until then it's a Severance check and Unemoloyment.
I don't want to be out of work! :confused:
Sorry, had to vent. Rich
Man that sucks.
Isn't there a good market for welders? I'm under the impression that if you want to make some cash you can as a welder. The only down fall to it is you have to bust your butt. Welding is not an easy job as in the high paying ones are the ones that demand a lot of physical action. Hot working conditions, tight spots or working around hazzardous area's. At least that is my understanding.
So at least you still have a good job skill to fall back on.
Sorry to hear about that, Rich. Went thru similiar thing last fall. Factory shut down (move to mexico) and had to find a new job. Happier now, better hours, more money. Worked out well for me and I'm sure it will for you too. Keep optimistic!!!
:confused::cheers::devil::flag:
That certainly does suck!!! I hate to see anyone lose that much time that they have invested in their pension. I hope you get recalled or find something better!!!
To bad man . I hav been watching the new FCC rule flying through the usual channels with no opposition. Looks like there wont be much competition in the news broadcasting market soon. I hate to hear about anyone losing a job they love but it might be an opportunity to try something new. Thats what I did and have found a new life.
Good luck.
That sucks, but at least you have other skill areas to help you out in the search. I wish you luck- I know my brother spent a good deal of time finding the right job over the last few years.
I'm sorry too, But I understand more than most as I'm losing my job in less than a week. Due to political bullsh*t. I'm an Electrical Engineer that don't kiss a** and that is why I'm out. But I'm sure I'll be ok in the end. And you will be too. Good Luck Bud.
AD Nealy Sr.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
