Wheel spacers
  • Replies 31
The only con I can think about is they will make you need additional trimming of your wheel liner
It could theoretically cause early outer wheel bearing wear.
Is that common issue? I never used spacers so I have no idea.
Sent from my SM-G920P using Tapatalk
I'm not sure in a truck that should have some heavier duty parts. In sports cars, yes they do. A full size truck? Not 100% sure
I've been running two inch spacers all the way around since April and haven't had any problems with them.
I would hope that it wouldn't escalate failure by 90k miles. Kind of like saying that you've been running with scissors since April. Haven't gotten hurt yet... But sooner or later you're gonna get cut. probably sooner than with not running with scissors.
I've used spacers in the past as well but when my bearing start to go I won't be surprised.
The spacers are more of a temporary thing for me until I get around to ordering bigger wheels and tires though
I was thinking about getting .25" just for appearance ( hopefully) but not sure that small is even noticeable. Anyone?
With spacers that thin you will still be using the stock lugs. Thats .25" less thread that you will have. You could always put longer lugs on but thats a different story.
Which spacers?
Not sure what exactly you're going for, but this is how much an 18x9 wheel with 2" spacers will stick out.
What's the offset? 2" spacer on a +26 and on a -15 are going to way different
    contrabombarde
    contrabombarde
  • Who's Online   0 Members, 0 Anonymous, 829 Guests (See full list)
    • I'm sure if you went to a junkyard where you go in and pull the part off the truck yourself, not a used part place where they do it for you, you can get that part on it's own.  Depending on if and what else you would be buying, and time of day, they might even just skip over adding it as a item to the bill.
