What are your thoughts ...ugly or nice?
Jeff5347
I'm torn. I had a friend at my kids football practice say black all the way. I do like these 18s the best out of the other stockers I've seen. Im pretty sure when I get rims they'll be 18s as well but my tires only have 10k so to new to replace I wish there was a tungsten that had this done for related to see what it really looks like. In the pic the lugs are black too but I would leave them solver to break it up bit
Sent from my Nexus 6P using Tapatalk
