Dash lower center door *how to remove*
there a screw - between the two rubber bumpers , maybe some clips also .
That compartment is part of that whole lower center panel section (the 12v outlet included). 3 bolts and some trim clips hold the panel in. You may however, be able to remove the door like a glovebox on most cars, where you squeeze the sides of it in so it pulls the tabs out of the slides they are in.
for any future searches:
This is correct. squeeze the sides in and the door will swing down. then just un-hook the hinges.
It'd be good to edit your Original Post with the solution. Thumbs up.
    BigJake
    BigJake
  • Who's Online   4 Members, 0 Anonymous, 561 Guests (See full list)
