Fun with plastic!
HoosierZ
eBay item number 322214207376,they fit 1500 only not for 2500,3500 series.
6.00 plus 2.60 to ship.
Thanks man! Picked up the last pair just now.
I'll have to blow all the dirt out of there and then throw them in.
    zibzer2
    zibzer2
  • Who's Online   5 Members, 0 Anonymous, 839 Guests (See full list)
