Fun with plastic!
HoosierZ
After seeing the plugs to fill the crossmember tubes in the rear wheelwells, I decided to make my own instead of paying good money for some cheap looking shipping tube caps. I used 0.100" thick HDPE plastic and panel retainer push pins I had laying around. They seem to fit fairly secure but if they decide to pop out, I'll glue them in.
688814F1-706E-4474-83A6-9A6B34590C55_zps
E7ECC838-0B0A-4EE2-962D-9447A31CBC13_zps
12F2E1C3-23F0-4676-88D5-1B1FD757128B_zps
599DD4F3-C516-41F0-A45F-E77F244D7186_zps
My next project was to do something about the front bottom edge of the wheelwell. After I removed the air deflectors from in front of the rear tires, it left the area looking unfinished compared to the back of the wheelwell. I used the same HDPE to make some trim pieces to give it a cleaner look. They are attached with the original screws.
7E2E3CAF-A241-4298-94C4-85C1DB70AD3E_zps
0EFE0B3C-5DA4-41D9-8887-5CB85A4E9F08_zps
E59923A4-E56D-43C0-A466-5BB360B7C5F9_zps
Thanks guys.
HDPE is very easy to work with. It seems to be similar or the same as what motor oil bottles are made of. I cut it with a box knife and tin snips. It's soft enough that it can be bent easily by hand without cracking. I found it in 24"x36" sheets at Menard's for $20.
Great to know. I would have thought you used a heat gun or something. If you did that by hand I'd imagine you could do some pretty great stuff with a heat gun.
this is AWESOME!
i was out today driving right past an 'industrial plastic' store
stopped in and for $5 got more than enough HDPE to make the cross member plugs. the plastic i got has a nice texture on it too. if it didn't i was just going to spray it with some undercoat
hopefully have time to do this on the weekend!
great post HoosierZ!!!
Love the idea of the wheel wells, my only suggestion would be to either grease the metal part before screwing on the piece or use a good spray wax or oil based undercoat just so you don't trap more water or moisture
$_1.JPG?set_id=880000500F I bought these for $8.00 shipped they are textured and thick not flimsy.
I also purchased these, less than $10 bucks delivered. These are high quality plugs, not the cheap plastic super thin plastic tube plugs. I'd recommend this type for sure, it's better than anything I could have made myself.
That is nice work I just don't have time/skill went with these too.
Do you have a link to where you got them?
eBay item number 322214207376,they fit 1500 only not for 2500,3500 series.
6.00 plus 2.60 to ship.
