Upgrading headlights on 16 2500hd ltz
Jlash
Been looking around the forumn and some other sites as to what lights my truck has. The low beams (top lights) appear to be a projector, but are they hid or halogen projectors? The temperature of my stock lights is a warm white and i want switch to a pure white with more out put and then am not sure what to pair them with for my high beams and the fog lights. I have never owned a vehicle with projectors, so im kind of lost..
I had a chance to go out and look under the hood, the low beams are halogen projectors (H11 55W), high beams are halogen reflector (9005), and the fogs are 12086
I will be putting 35w Morimoto 5500k low beams in my truck, then I'm looking at 6000k LED bulbs for high beams and my fogs. Another member here did that and said the color match is almost perfect
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
