Auto fogs with headlights
AZ71
Is there a way to get the fogs to automatically turn on along with the auto headlights? Don't want to have to click them on each time.
The only bad with that mod is if you short out anything and it fries the BCM you are on your own with the dealer. One member has already ran into that issue and was stuck with the repair bill.
^This.
That's why I'll push the on button every single time.
^This.
Ditto. I bought the diodes, and then decided it wasn't worth the risk.
