This is why you won't find just a grill insert!
OmniCamaro
I planned on painting the black part of my 2016 grill this weekend. I proceeded to take the front grill off my truck, really easy, and brought it inside to separate the chrome from the black plastic. The picture should explain everything. There are about 50 tabs connecting the chrome to the black part. Um, no thanks! This is a great example of major overkill. Now I see why they do not sell the inserts separately. Guess the search is on for a whole new grill.
Use tooth pics to hold the clips back. Maybe need to use a hair dryer to keep them breaking.
Toothpicks? As much as the response is appreciated, that's just funny. After an hour or more I only managed to get 3 tabs loose on one end of one row and I was using metal pry tools. I bent a couple of screwdrivers as well. There must be a very special tool for this job if it's even possible.
The heat suggestion is a good one. I'll need to remember that one.
I haven't tried to do it yet; however, on my Audi we have a similar issue with the chrome onset of the grill, about 36 clips. The square tooth pics will hold the plastic from clasping back over the lock on the other piece of plastic. Maybe it doesn't work here. The purpose again is just to keep it from locking back over itself.
Toothpicks work....on each tab you will find two black clips. Only one clip has a holding indentation. Pry that particular holding tab with a screwdriver and insert the half toothpick to hold open. After about 20-25 tabs just slide the chrome shell off. It is really easy.
I didn't understand about the toothpicks at first but I get it now. I have quite a few tools and I couldn't find one that would allow me to pry those clips out/apart. If I could get them apart I might would move forward with the paint option.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 468 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
