Post pics of fox 2.0 setup.
Baldasian85
I am considering the fox 2.0 coil over setup. My 2015 GMC Sierra Denali is level with the 2.25 Readylift with 305/55/20 and it rides like crap. I would like to keep the wheel setup. But was wondering would the fox 2.0 coil over clear my wheel setup any info would help. Thanks y'all.
Yours is 33.2(33.13 to be exact) inch tire over all.
What does the fox kit say? It should have recommend tire size range. But if I had to guess I would say yes it should fit because you can technically fit a 33 inch tire with just a level.
Same im sick of my leveling spacer it rides like a wheelbarrow. i have fox coilovers on order and will install sometime next week.
It honestly probably has more to do with your tires, but yes the coilovers will help. I have the fox 2.5 coilovers with reservoirs and DSC and they are awesome. It will definitely be an upgrade. However like I said the tires are most likely the biggest contributing factor especially because many tires that particular size only come E rated (10ply).
