Max towing package question
06trdrew
Hi guys,
I bought a used 2016 Sierra 5.3L, 3.42 SWB, Crew cab, which has the factory IBC and 12k max hitch installed. (I'm assuming it's a class 4 hitch but I have no marking on it other than 12k towing and 1200lbs tongue weight sticker)
How do I confirm that I have the Max towing package on this truck? Can I tell by the Vin# I'm curious if I can tow 11'100 lbs or 9'400 lbs Max rating. Thanks
I initially thought only max towing package only came with the 8 speed tranny and 6.2L option
MAX TRAILERING PACKAGE Includes 9.76" rear axle, 3.73 axle ratio with 6-speed automatic, 3.42 axle ratio with 8-speed automatic, trailer — brake controller, enhanced cooling radiator, revised shock tuning for increased control, heavier-duty rear springs and increased RGAWR to 4300 lbs. On SLE, includes Trailering Package and locking rear differential on 2WD models. Also requires UHN 18" or RD3 20" aluminum wheels, 5.3L V-8 engine and power camper mirrors. Not available with Z71 Off-Road Suspension Package. On SLT, requires RCW 18" or RD5 20" aluminum wheels when ordered with 5.3L V-8 engine. Also requires 20" aluminum wheels when ordered with 6.2L V-8 engine. Not available with Z71 Off-Road Suspension Package.
Excellent information
I did not find the NHT like you mentioned in the glove box.
Although now that I have all these 3 digit codes I might start looking all these up to see what they all are
  • 1 month later...
NHT is the correct RPO for max tow.
The telescoping camper mirrors are the easy identification for max tow, they are in the package
    LeeBob
    LeeBob
  • Who's Online   5 Members, 0 Anonymous, 607 Guests (See full list)
