Headlight switch spring removal
TPA335
On 9/18/2017 at 12:10 PM, SilveradoSaver said:
So this may be a stupid question, but why does GM prevent you from turning off the lights with this spring? The new vehicle I purchased I can fully turn off the lights without interference of a spring. Is GM the only one who does this?
I believe GM did this to prevent people from accidentally driving with their lights off and not realizing it. I went to jumpstart someone who also had a newer gm with the same switch and their headlights were on while they were waiting for me to hook up the jumpers. I asked them to turn their lights off and they said that they don’t think they are able to turn them off. I had to show them how to.
I have HID’s so I don’t want them turning on for DRL every time I drive during the day. I sanded part of my switch down so it goes further towards the off position instead of being half way between off and auto. I keep it in the off position all the time and to turn it on at night I flip to auto and then back to off so the next time I get in the truck it’s in the off position. The lights stay on until the truck is turned off again.
    250.3k
    Griffin Donovan
    Griffin Donovan
  • Who's Online   4 Members, 0 Anonymous, 675 Guests (See full list)
    • Hasn't come up in the 3 gm forums I follow. And only gm knows the frequency of failure of that part. LMG, you want a recall so it's replaced for free...
    • You need a better code reader/scanner.  You are missing codes.  Did the dealer give you a copy of the SAVI scan from that visit?     If the fluid hasn't been changed, change it.  Shudder will likely go away.
    • TLDR to my other post...   Hard. Pass.  Too many what ifs.     Are you set on a 3.0 Duramax?  Have you considered anything not GM just in case?  If you don't have to have a pickup, lots of other options for $27,000 out there.
    • I see some red flags.   - No mention in the Carfax if the oil pump belt was changed.  LM2s had a 150,000mi service interval, and its got 164,245mi on it.  So right out the gate it needs about $3000-3500 for that to be done before driving it another 150,000mi.  Belt is at the rear of the engine.     - If something happens to the transmission valve body, the special coverage is expired by mileage.  That will likely be an out of pocket expense, with zero or near zero GM participation if something happened even though its in by time.   - 2020 LM2s seem to need timing chains after 80,000mi at some point.  They fixed this end of 2020/starting 2021 model year engines.  They will usually set a P0016 I think?  There is another $8000-10,000 if it needs a chain.  The main chain is at the back, secondary at the front so the pump belt would be done at the same time if it needed chains.     - Long oil change intervals.  7,000-8,000mi on average, probably close to 0% or perhaps to or beyond 0% on the OLM.  Lots of them not at the dealer which makes me wonder how much of the oil ran through that truck was the proper Dexos D rated 0w20 oil and not just gas engine 0w20, which is not the same at all.     - Long fuel filter changes, again likely taking the fuel filter life to 0% or more.  First one went 28,603, second was done 43,094 miles later at 71,697, from there another 46,452mi to 118,149mi, and then the most recent one 37,026mi later at 155,175mi.  So counting its original fuel filter, its had only 4 fuel filters on it.  No bueno IMO.         Good news?    - It has had only two warranty trips to the dealer.  The first free service (end of December 2020 on the Carfax), and the transmission reprogram recall (end of August 2025 on the Carfax).     - Truck did a LOT of moving, so that might explain the lack of emissions related repairs like bad NOX sensors, bad exhaust temp sensors, bad glow plugs, etc.         The "emissions system checked" could just be how something was flagged for Carfax.  GM dealers have to do SAVI reports for warranty repair orders so they scan the truck.  So its possible that is there for that?
    • Thank you, @Z45!   NOTE - No all repair shop/Dealers reports to Carfax   That is my main concern.  The CARFAX looks way too clean for a 6 year old anything with 164,245 miles.  Even something known for reliability (like many Toyotas) typically has a lot more replaced, like a Nav screen, interior trim, shock/strut, or brake pads.  And surely the last set of tires (installed at ~58k miles) would be bald unless those were all highway miles.   I'm tempted to pay a local dealer to look up the VIN, but am not sure if that will be worthwhile.  Last time I did this, it was 100% useless, and I felt scammed - they noted the bumper was replaced years ago and that's it.  A 5-year old could spot the accident damage, even though nothing was on the CARFAX.   After giving the dealer a call, the truck may have a hard shift, but they have to verify with their mechanic if that's even a concern.  And I've test driven about a dozen of these now, many near Chicago, and half the trucks shift hard/odd at all throttle positions.  The ones with aftermarket lifts/larger tires shift terrible, and 3 stock trucks shifted so violently I thought the transmission valve body was going out.   At this point I'm conflicted, as I need a vehicle, and am coming up short locally.  Northern trucks in this price range tend to have either multiple owners, a lot of mods (lifts/oversized tires without re-gearing), and are generally in rougher shape.   If this truck showed up in your neighborhood for $27k and you had to purchase it sight-unseen, with the possibility of needing a 10L80 rebuild, torque converter, or rear end - would you do it?  I'm convinced most of the 10L80 trucks I test drove are broken, they can't all shift so bad, with massive flares/slipping/lurching and mis-matched downshifts like a teen driver learning stick.
