Headlight switch spring removal
TPA335
Anyone have a DIY/instructions on how to remove the spring from the headlight switch.
i found out how to get access to the knob with this video.....
once you have access to the back of the panel you can pop out the actual control knob
i didn't actually take my completely apart... just enough to get it to illuminate blue instead of white....
you can also pop the center part of the knob out with a small flat screw driver (see below for where to pry.... just slowly and carefully work around the top)
Why would you do this?
Sent from my SM-G920V using Tapatalk
I'm with you on this^^^,is there a free mod I don't know about?
Allows you to take the switch out of the auto position so the DRL don't come on.
i don't remember a spring - there was a bar running thru the housing and 'cogs' on the dial that kept the dial in a certain position
something like this (red = metal bar)
when the bar was out i could set the dial where ever i wanted.
Exactly. I just put HIDs in and don't want the DRLs coming on every time I put the truck in gear.
  • 1 year later...
Anyone know why I cannot see the pics for this mod I get a message please update account to allow 3rd party hosting. I took my switch off the dash now can't figure what to do next
I just did this today. Take everything apart until you're in the guts. Once inside you'll find a small spring in one of the corners. Remove it and reassemble. Now you'll have four positions on the knob instead of three.
I took the spring out but why if it is switched to off when I put back into auto the drl do not come on. I need to switch it to auto then off and back to auto to get the drls to come on? Is this correct. I thought if it was in off and I moved to auto then the drl and auto headlight functions would work the first time it was switched. I need to switch to off then auto again for the drls to come on. Does anyone also know how the spring goes back in? Mine fell out when I opened the switch and I never saw the way it was installed.
So this may be a stupid question, but why does GM prevent you from turning off the lights with this spring? The new vehicle I purchased I can fully turn off the lights without interference of a spring. Is GM the only one who does this?
photobucket wants me to give them $400/year so the pics on their page will show up on forums - sorry... not doing it!
here is a direct link to the pic/drawing i had posted in post #6... http://s763.photobucket.com/user/bc-chris/media/cp1/knob1_zpsdrdmzg4f.jpg.html
from post #2...
first pic: http://s763.photobucket.com/user/bc-chris/media/2014%20silverado/IMG_1415_zpspdudbt7i.jpg.html
second pic: http://s763.photobucket.com/user/bc-chris/media/cp1/knob_zpsow349m8b.jpg.html
GM are the only ones I have ever been in where there is a spring. I know Honda and Toyota have no spring.
    Patrick Fergy
    Patrick Fergy
  • Who's Online   4 Members, 0 Anonymous, 963 Guests (See full list)
