Ditched the wood grain interior trim!
gregrob20
I decided I was sick of the wood grain trim in my 15 SLT. The pieces on the center console were the only areas of the whole interior that would actually rattle if you tapped on them, and I hated the fake wood look.
So.... Here's what we did. A friend who also has a 15 decided to hang out and do his as well since I had plenty of material. I think it turned out stellar. Makes the truck have a whole different feel inside to me. Not too much carbon, just the right accent amount.
BEFORE:
14257515_10153879622497338_2914758682924
14207669_10153879622272338_6415140250641
Nice work!
Only issue I see is that there is no beer in any of the progress pics.
Love that! I'm looking into having mine hydro-dipped black kryptek camo (love that shit). They look fantastic, especially with the black leather.
Sweet. I was going to go the hydrodip route but I already had the 3M wrap sitting around. I love it more every time I get in the truck. Feels so much different than the poorly implemented fake wood.
It looks GREAT! What is the material that you used? Does the trim just pop off?
He using Dinoc "carbon fiber" not sure which color but there quite a few carbon fiber colors, Dinoc is a textured and very forgiving vinyl. I really love ME-379, its like 2 colors in 1!
on the other forum heres some pics of my 2013 Denali its amazing stuff, but even with the 3m glue around the edges it started to peel in the TX heat.
http://www.performancetrucks.net/forums/show-shine-discussion-129/dinoc-me-379-a-526192/
The textured wrap looks much better with the carbon fiber. Looks more high end. Hydrodipped carbon fiber looks like crap IMO
3M Carbon 1080 Scotchprint vinyl wrap. Not Dinoc....
Dinoc is a lot stiffer and harder to contour, and a lot of people say the 1080 looks more real as well. They both look cool but 1080 is easier to work.
I used the 3m primer too on all the tight contours and edges just to make sure I had great adhesion, then set it all with a heat gun when I had it trimmed and stretched.
The pieces pop off the doors but usually leave the metal clips, so you have to pull those and reinstall them back on the pieces. The center console snaps apart and then you have to remove a screw from each side of the trim there to get it out.
I would bet 1080 wouldn't peel. Dinoc is hard to get to lay on tight contours.
Just checked out the link. Looks great man. Sorry to hear it's peeling.
How hard would it be to wrap the silver on the steering wheel and around the radio to match?
I don't like the woodgrain and am thinking of this. Just have the doors, no console, but it looks like I'd have to get a lot more material. And then what do I do with it?
I did the same thing to my AT, I like the look of the textured CF over the glossy CF print on those pieces. The rears are a botch though, compound curve on the bottom makes them a pain to get the wrap to lay flat with no wrinkles.
I want to do the steering wheel and the vent/radio bezel next.
    Sothpaw27
    Sothpaw27
  • Who's Online   1 Member, 0 Anonymous, 443 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
