2014 Silverado Cargo light bypass
Not sure what you mean by canopy light sensor, but if you mean the cargo light, I don't believe you can. Not easily, at least.
Do you mean having the cargo lights on while in reverse for extra lighting?
Yes but I have the 2014 tow mirrors with the led lights on side and since they use cargo lamp button I can only turn on when in park
Look up the diode mod where you can add it
On the bcm and your cargo lights will come on while in reverse. It will also power your bed lights at night if you have them.
Your cargo lights will come on with your reverse lights. You'll have 4 back up lights after this mod. No need to use the switch since they'll be on already.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
